Activity Forums Adobe Photoshop Configuration Error 1
  • Configuration Error 1
    Posted by Paul Benson on December 27, 2012 at 5:57 am
    I built a new system over the holidays and installed a new CS6 suite. It is the Educational version, so while I am waiting for Adobe to bless the paperwork and send me a serial number, I am using the 30-day trial. I am also using Win7 Ultimate 64 bit.
    I have an SSD and put the OS on it and then have a standard HDD for the applications. I did a registry edit to point to the standard HDD for Program Files and Program Files (x64). Apparently, Adobe does not like this and hardcoded some code to look at the C:\ drive. I have found some posts that point to this problem:
    https://feedback.photoshop.com/photoshop_family/topics/photoshop_cs6_extended_configuration_error_1
    https://forums.adobe.com/message/4660774
    The posts above a little old and I was wondering if anyone has found a better solution than changing the registry back to C:\… or copying all of the files from C:\ to the Apps drive. I did copy the files and now the 32 bit versions work, but the 64 bit photoshop keeps asking me to approve the Ts&Cs without ever launching.
    Did Adobe fix this in an update?
    How are others working around this?
    I have to imagine that more and more people are going to use SSDs and want to keep it as pure OS as possible, so I am hoping Adobe fixed this.
    Paul
    Paul Benson replied 13 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
