Activity Forums Adobe After Effects Expressions Conditionals and wiggle on two dimensions
  • Conditionals and wiggle on two dimensions
    Posted by David Cabestany on May 11, 2015 at 7:25 pm
    I’m trying to use the expression below to control the scale of one layer when a person is talking, but it breaks every time it runs, the errors are:
    Array piece can’t expand to more than one value when I finish the expression with [x,x] and
    Expression result must be if dimension 2, not 1 if I change the end to x.
    The idea is to have the layer scale and shake when the person talks and still when the person is quiet.
    Can anyone help?
    s=thisComp.layer("hostess").effect("Both Channels")("Slider");
    if
    (s>=5)
    x=(wiggle(2,10));
    else
    x=100;
    [x,x]
    Dan Ebberts replied 11 years, 3 months ago 2 Members · 3 Replies
  • Dan Ebberts
    May 11, 2015 at 8:44 pm
    wiggle() already gives you an array, so sticking it in brackets (as variable x) won’t work. Try it this way:
    s=thisComp.layer(“hostess”).effect(“Both Channels”)(“Slider”);
    (s >= 5) ? wiggle(2,10) : [100,100]
    Dan
  • David Cabestany
    May 11, 2015 at 10:55 pm
    Thanks Dan,
    I revised to this:
    s=thisComp.layer(“Audio VO”).effect(“Both Channels”)(“Slider”)
    t= linear(s,0,8,100,165);
    if
    (s>=1
    && time>=38
    && time <=62
    {[t,t]
    else
    [100,100];
    Depending on the layer I change the time values.
    I’m not very familiar with this other writing convention you’re using, the question mark and the colon. I think I saw it once but that’s it, I’m guessing the ? means “then” and : means “else”, but I don’t see anything that means “if”
    Is the old writing convention bad? Does it slow the program or something?
    Thanks again.
    D.
  • Dan Ebberts
    May 12, 2015 at 1:34 am
    In JavaScript, ? is the conditional operator, where the “if” is implied. It’s just a more compact notation that I like when the logic is simple.
    Dan
