Activity Forums Adobe After Effects Expressions Conditional statements with multiple values and multiple results
  • Conditional statements with multiple values and multiple results
    Posted by Sean Kimber on April 8, 2020 at 8:10 pm
    I have another expressions question. :slightly_smiling_face: I was wondering two things about if/else conditional statements. I have 4 values. I want to say that if a is greater than b, c, & d, then the width value = x and the height value = y. (There wouldn’t be a variable in the x & y spot – it would be a specific value). Then I want to do the same for b, c, & d.
    My questions are:
    A.) Is it possible to check which value is the greatest without having to write out if(a>b && a>c && a>d)? It’s a lot of typing. I’m fine typing it for each value, but I’m wondering if there’s a shortcut.
    And
    B.) Is it possible to have more than one result in a conditional statement? If so, how do I write it. I basically want to say, “If (a==true){width = x.width && height = y.height},” but that always produces errors. Is there a way to do this, or do I have to write the conditional statement twice, once for width and once for height?
    Thank you!
    UPDATE: I’ve tried 2 options, had some success with the first, none with the second:
    1st Option:
    a = thisComp.layer(“TEXT”).sourceRectAtTime();
    b = thisComp.layer(“TEXT 2”).sourceRectAtTime();
    c = thisComp.layer(“TEXT 3”).sourceRectAtTime();
    d = thisComp.layer(“TEXT 4”).sourceRectAtTime();
    if(a>=b && a>=c && a>=d){
    Width = a.width;
    Height=a.height;
    }else if(b>a && b>c && b>d){
    Width = b.width;
    Height = b.height;
    }else if(c>a && c>b && c>d){
    Width = c.width;
    Height = c.height;
    }else{
    Width = d.width;
    Height = d.height;
    p=thisComp.layer(“EFFECTS”).effect(“box margin”)(“Slider”);
    if(Width!=0){
    x=Width+p*10
    }else{
    x=0
    y=Height+p;
    [x,y]
    Attempt 2:
    mX = Math.max(a, b, c, d);
    if(a == b && a == c && a == d){
    Width = a.width;
    Height = a.height;
    }else{
    Width = mX.width;
    Height = mX.height;
    if(Width!=0){
    x=Width+p*10
    }else{
    x=0
    y=Height+p;
    [x,y]
    Dan Ebberts replied 6 years, 5 months ago 2 Members · 1 Reply
  • Dan Ebberts
    April 8, 2020 at 9:24 pm
    You can use Math.max() to compare multiple values, like this:
    Width = Math.max(a.width, b.width, c.width, d.width);
    That should help simplify things.
    Dan
