Activity Forums Adobe After Effects Expressions Conditional expression needed (if/else) with command “or”
  • Conditional expression needed (if/else) with command “or”
    Posted by Aled Rhys jones on May 23, 2008 at 5:00 pm
    I have this expression which is giving me an error:
    if(thisComp.layer(“Null”).effect(“Layer Control”)(“Layer”) == “5”OR “6” OR “7”) “A” else “B”
    What I’m after is a condition set where if an operator selects any of these three layers 5, 6 or 7) through the effect(“Layer Control”) then the expression should give reply “A” and if it’s any other selection (1 to 4 or 8 and above) then the expression should give the reply “B”
    Any help would be greatly appreciated,
    Mo Dejong replied 18 years, 4 months ago 2 Members · 1 Reply
  • Mo Dejong
    May 23, 2008 at 5:50 pm
    You need to use (var == value1 || var == value2) in
    expressions. For example:
    var layer = thisComp.layer(“Null”).effect(“Layer Control”)(“Layer”);
    if (layer == 5 || layer == 6 || layer == 7) {
    A
    } else {
    B
    cheers
    Mo DeJong
