Activity Forums Audio Concert DVD
  • Concert DVD
    Posted by Gregorio Pellegrino on January 11, 2010 at 3:30 pm
    I’ve registered a concert.
    Have I to normalize every track separately?
    Or can I normalize all toghether?
    Greg
    Ty Ford replied 16 years, 8 months ago 4 Members · 9 Replies
  • 9 Replies
  • Ty Ford
    January 12, 2010 at 12:56 am
    Hello Gregorio and welcome to the Cow Audio Forum.
    Why do you have to normalize anything?
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Gregorio Pellegrino
    January 12, 2010 at 6:01 am
    Because my DVDs have always low volume so I want to normalize the audio.
    But I don’t if I have to normalize every track separately or all the video (between a trak and the next there is some spoken).
    Greg
  • Ty Ford
    January 12, 2010 at 10:53 am
    Greg,
    Normalizing is too general a procedure. How come you’re not mixing your audio to the proper level during post production?
    Regards,
    Ty Ford
    January 12, 2010 at 10:59 am
    I’m mixing the audio of two sources: the mixer output and the panoramic microphone of one camera.
    The problem is that some songs has lower volumes than others (some songs are instrumental only). So I want to normalize all to 0 db, for the DVD.
    Greg
  • Ty Ford
    January 12, 2010 at 11:21 am
    What system or program are you using to postproduce your video?
    Ty Ford
    January 12, 2010 at 12:12 pm
    I use Final Cut for the video and Logic for the audio on MacOs X.
  • Richard Crowley
    January 12, 2010 at 6:07 pm
    Without knowing anything about your recording or the style of music, etc., it seems very unlikely that simply normalizing the entire concert recording will yield good results. It is typical to apply level adjustments (at minimum normalizing each segment) separately to each song and each speech segment.
    It may be that normalizing the loudest songs and maybe the speech to 0dB Full Scale may be appropriate, but only you can make that decision because you have the video and audio to work with and know what the music should sound like. You probably wouldn’t want to normalize ALL the songs to the same level. Unless they are all max-volume head-banging heavy metal or something. 🙂
  • Bouke Vahl
    January 12, 2010 at 6:20 pm
    Greg,
    Ty is very understanding and easy going.
    I’m not.
    You have to MIX until YOU think it sounds good overall.
    No matter the tools, just do what you think needs to be done.
    Normalizing is (open for discussion) setting the max peak of a piece of audio to a certain level, and adjust all other levels accordingly.
    This is not what you are after.
    Mix, then export to 16 bit @ 48K, set peak level to about -6.
    Then, if you go to AC-3, make sure you know what you are doing there.
    If in doubt, go to one of the DVD fora and ask for settings to create good AC3
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Ty Ford
    January 13, 2010 at 1:38 am
    Gregorio,
    FCP has simple but effective mixing tools. Use them to get peaks about -3dB at the higherst.
    Regards,
    Ty Ford
