Activity › Forums › Adobe After Effects › Concentric squares
  • Concentric squares
    Posted by Putopian Vohra on November 16, 2011 at 7:19 am
    Hello all
    This is my first post in this forum.
    I have two doubts.
    1) How can I create concentric squares with animation like this
    2) How can I create a perfect circle/square in a comp with a non-square pixel aspect ration? Even when I press shift while creating the path, it appears stretched.
    Putopian
    Putopian Vohra replied 14 years, 10 months ago 5 Members · 6 Replies
  • Brian Charles
    November 16, 2011 at 3:51 pm
    Use Radio Waves (Effects >Generate>Radio Waves) and set the shape to a 4 sided polygon then rotate it 90 degrees.
    You can animate the frequency, expansion and colour of the waves.
  • Roland R. kahlenberg
    November 16, 2011 at 3:59 pm
    As Brian has suggested, Radio Waves will do a good job. Shape Layers are also worth a look into.
    As for your perfect squares and circles, stay away from non-square PAR comps – it’s really as simple as that. IOW, stay away from working in non-square PAR comps. All it does is to create lots of unwanted issues.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Michael Szalapski
    November 16, 2011 at 5:04 pm
    However, if you must work with non-square pixel aspect ratio comps, make sure to toggle the pixel aspect ratio correction switch.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Walter Soyka
    November 16, 2011 at 6:42 pm
    [Michael Szalapski] “However, if you must work with non-square pixel aspect ratio comps, make sure to toggle the pixel aspect ratio correction switch.”
    Indeed. It’s right below the comp viewer and it looks like this:
    Walter Soyka
    November 16, 2011 at 6:55 pm
    [Michael Szalapski] “if you must work with non-square pixel aspect ratio comps”
    meh? I’ve never had a scenario where I’ve had to work within the confines of a non-square PAR comp. Even AI provides for only square-pixel PARs presets. Photoshop still allows for non-square PAR presets but I think that may go out of the window in due time.
    Cheers
    RoRK
  • Putopian Vohra
    November 17, 2011 at 5:28 am
    Thanks everyone.
    It helped me very much.
    Putopian
