Activity › Forums › Apple Final Cut Pro Legacy › Computer won’t start up
  • Computer won’t start up
    Posted by Carlton Hathcoat on June 23, 2009 at 5:51 pm
    I know this is for FCP but maybe an editor has run across this problem. When I turned on computer, the computer is on (the white light is on), you here it warm up for a couple seconds, then there is silence and nothing happens after that. This happened for the first time yesterday and I turned the computer off and on a couple times and finally got it to work, but it has happened again today. Anyone ever have this happen, and any suggestions? This is a 3 year old G5 if that helps.
    David Bogie replied 17 years, 3 months ago 4 Members · 3 Replies
  • Dennis Leppell
    June 23, 2009 at 6:59 pm
    My guess….failing hard drive or processor. backup immediately.
  • John Fishback
    June 23, 2009 at 9:28 pm
    Run Disk Warrior.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • David Bogie
    June 24, 2009 at 4:04 pm
    You do not need to buy Disk Warrior. The new edition of Macworld has an excellent troubleshooting feature article worth buying the issue.
    Once you get up and running, run a clone of your drive. A clone.
    Run Disk Utilities to rebuild the permissions but do that AFTER you’ve backed up your drive.
    Restart holding down the shift key this will initiate a safe boot and do a bunch of disk maintenance routines.
    Disk Utility cannot run a repair run on your active system drive unless you start from an external system drive or the installer disk for your machine. Find it. Start with the C key down, when it finally boots form the optical, under the tope menu you will find Utilities. run Disk Utility to repair your drive.
    bogiesan
