Activity Forums Adobe Premiere Pro Computer that can handle Premiere
  • Computer that can handle Premiere
    Posted by Derek Diamond on July 12, 2012 at 4:13 pm
    Hi, this is my first post here.
    I’m not that great with computer specs, so I need some advice. I’m a freelance videographer and recently got Adobe Premiere Pro. I love it, but it seems like my computer can’t handle it. It slows my computer down and videos that are only 15 minutes in length take up to 3 hours to render. I found a computer that seems to be more than capable of handling it, but I’m not totally sure. The computer is a:
    TOSHIBA DX735 23-Inch TOUCHSCREEN All-in-One EXTREME
    3 TB Hard Drive
    16GB RAM
    (Intel Core i7 processor i7-2860QM second generation – 2.50GHz with TURBO BOOST to 3.60GHz)
    Full HD 1080p 1920×1080 display resolution
    BLU-RAY Windows 7
    Desktop PC Touch Screen DX 735 Series
    Can anyone let me know if this is the computer for me?
    Alex Gerulaitis replied 14 years, 2 months ago 2 Members · 1 Reply
  • Alex Gerulaitis
    July 12, 2012 at 7:59 pm
    In a word, not recommended:
    – graphics is usually inadequate
    – possible issues with adding a dedicated media volume
    – AIO systems are usually skimpy on expandability and upgrade-ability options
    – AIO systems are usually slightly more expensive than their desktop counterparts due to tighter packaging
    So…
    Graphics. What is the graphics chipset / card on this system? Intel HD? If so, no GPU acceleration for you – a major benefit of Pr CS5+.
    Storage. Everyone will tell you not to use the boot drive for video, and preferably use some sort of a RAID setup. Some (extreme gearheads) will even tell you to set up separate physical volumes (drives) for output (encoding), caching, etc.
    With AIO (All-in-Ones), unfortunately, having one or more separate secondary volumes may not be as easy as with regular desktops. If it has a USB 3.0 or eSATA then you will be in a better position.
    Bottom line: unless it’s an HP Z1 (and even that – with some reservations) – I’d stay away from AIOs for serious editing.
    Alternatives: HP Z-series (Z420 and up), Dell T3600 and up (T7600 is my fav), custom systems from ADK, Puget and the likes; properly done DIY systems ($1.5K and up) if you feel like it.
    Alex Gerulaitis
    Systems Integrator
    DV411 – Los Angeles, CA
