Activity › Forums › Adobe After Effects › Computer system
Computer system
Posted by Sean Stringer on August 31, 2006 at 9:25 pmHey Guys-
It’s new system time here – our options so far have been an alienware dual processor, custom built, or a mac.We will use the system for editing/compositing needs.
Getting a Mac would mean having to get new software, but we’re open…
Any opinions on the options or a good brand name to shop for?
Sean Stringer replied 20 years ago 6 Members · 13 Replies -
Vince Becquiot
August 31, 2006 at 10:37 pmThis is gonna start another MAC VS PC thread I’m sure, but I recently purchased the MJ-12 8550 (Alienware).
Couldn’t be happier…
Vince
Majorasshole
September 1, 2006 at 1:06 amWhy Alienware only? They’re only bling. You can get better performance from a PC for a fraction of the price without all the goofy moulded plastic and chromed alien heads. If your bosses are concerned with blingy computers rather than well perfoming ones, break out the rhinestones and bedazzler.
Vince Becquiot
September 1, 2006 at 3:55 am>”Why Alienware only? They’re only bling.”
I have to disagree. And there are plenty of benchmark reviews outthere to prove it.
I have built custom PC’s, I have also bought cheap PC’s (Some by Dell, which incidentally now owns Alienware)
These are very well built machines, and you get your money’s worth of performance as well.
If you are making money based on the time you spend working, and not the time you spend troubleshooting, then you’ ll go for proven reliability.
BTW, I am not saying that Alienware is consistently better than so and so, but you get what you pay for, we’re not dealing wine here…
Cheers,
Vince
Majorasshole
September 1, 2006 at 4:20 amWhy would you compare a cheap pc to an alienware? Spec a high end pc to an alienware and you get more performance per dollar. Do you need to troubleshoot your pc often? Mine isn’t an alienware and I didn’t even have to troubleshoot it the day I bought it. You spec the identical specs as the alienwares components and you get the same performance. Alienware simply has the components branded for them at the same factories that makes everyone else’s components. Just dont mis spec your machine. I suppose if you live somewhere with no decent PC retailers, and if you have no technical skills and no IT department then you would want to by an out of the box cookie cutter machine. But if you are a business you NEED someone with some technical savvy to spec your machines for you or you’re going to be burning money. With Alienware you are paying at least double the price simple for convenience or ignorance. Most alienware owners I know like to brag about it though. It’s kind of like mercedes owners, they like to be seen with the machine.
Vince Becquiot
September 1, 2006 at 4:46 amOk, this is turning into a flame thread, so I’ll keep it short.
I worked as a system admin for several years, which you would think would make me somewhat of a computer savvy.
You have been basically flaming Alienware without making A SINGLE SUGGESTION OF YOUR OWN !
The poster was looking for a recommendation, which I have given. I have paid $1700.00 for a complete machine than I find does a fine job for me whether I work in 1080p through AJA or 480i.
Vince
Eugene Perepletchikov
September 1, 2006 at 8:44 amDepends on what software and footage you want to use.
Macs are great but they don’t quiet give you the value for bucks that you would get with a pc etc. From recent experience, if you plan to use a lot of HD, especially dvcpro footage, then go the mac as there are various annoying issues with codecs etc for pcs. In general, all these new formats seem to lean more towards macs…By the way I am on pc, so if you don’t think that this will be too much of an issue, then go the pc or Alienware…
Sean Stringer
September 1, 2006 at 1:30 pmThis helps a ton!
I forgot to mention that we’ll be getting into HD pretty quick so I appreciate bringing that issue up as well.Vince, can I ask what processors(dual or dual core), ram, and videocard you picked for your alien pc.
I specked one out the other day at around $3100 w/ dual xeon. But I also would like to try the 64 bit dual core.Arson, what brands are you referencing for equal power, less cost?
Thanks zhenka for your objective addition…
John Baum
September 1, 2006 at 5:07 pmI got my custom system built by these guys. Much cheaper then Alienware or BOXX for essentially the same components. I even had my Decklink card drop shipped to them and they installed and tested it for no extra charge. There customer service has been occasionally a little mismanaged but they eventually get things right.
