Activity Forums Adobe Premiere Pro Computer (sometimes) does not detect camera as new hardware
  • Computer (sometimes) does not detect camera as new hardware
    Posted by Joe Landau on May 5, 2005 at 12:16 am
    I am capturing video from my SONY camcorder and have a lot of tapes. Sometimes, when I load a new tape and connnect the camera, the computer detects the camera as new hardware and I can capture video. Some other times however, it doesn’t. What is the proper way to connect and disconnect the camera so that the PC will detect the camera every time?
    Joe Landau
    Sameer Shrivastava replied 21 years, 3 months ago 4 Members · 4 Replies
  • Mickavid
    May 5, 2005 at 1:25 am
    I would think that using the Remove Hardware Safely function, you would be able to properly manage how the computer sees the device. Usually it is found in the lower right-hand icon tray on your task bar. If not, a quick search should locate it.
    Mick
  • Mike Velte
    May 5, 2005 at 11:49 am
    I have tossed out several firewire cables for that reason. Also have 2 cams where the firewire port has quit. Lots of “things” can fail.
  • Joe Landau
    May 5, 2005 at 2:23 pm
    Mike,
    Thanks for your response. The camera I’m using is a brand new SONY PC1000. I bought it because the firewire port on my previous camera was not functioning (what a waste of money to have to buy a camera for this reason !! A repair would have been about $300). So I buy the new camera and have similar problems to the old one. With this one however, I have a docking bay to which I connect the firewiree cable. This way, if the socket goes bad, all I have to do is replace the docking station.
  • Sameer Shrivastava
    May 7, 2005 at 11:48 pm
    I am also facing similar problems. with win 20000 if i upgrade my service pack above one it doesnot detect my camera/deck. even windows xp service pack2 does not detect camera. i have to check removing service pack for the camera. mostly i am using with avid dv.
    The docking station with sony camera has nothing inside to go wrong. i have opened it and found out. it just have connections. No chips or electronics.
    sameer shrivastava
