Activity Forums Adobe After Effects Computer Problems
  • Computer Problems
    Posted by Ori Burg on January 2, 2010 at 5:36 pm
    Hello Everyone,
    I have a problem with my After Effects CS4 project.
    My project resolution is 1024X768, and it have some HDV chroma key video files in it.
    The After Effects crashes all the time and the RAM Preview make the application Not Responding sometimes.
    My computer is not so bad:
    INTEL CORE i7 920 2.66GHZ CPU
    2x 6GB (3x2GB) DDR3 Total 12GB 1333
    Geforce 9800GT 1GB
    WIN XP 64 BIT
    Do you think it’s because the project is too “heavy” for the computer? What could be the problem?
    Thanks.
    Ori
    Tim West replied 16 years, 8 months ago 3 Members · 4 Replies
  • Walter Soyka
    January 2, 2010 at 6:00 pm
    You should search this forum for any post by Dave LaRonde with “Dave’s Stock Answer #1”.
    This first thing to try is transcoding your HDV footage to some other high quality format that doesn’t use interframe, temporal compression.
    Uncompressed, Animation, Photo-JPEG, and Avid DNxHD, or an image sequence are all good candidates.
    Walter Soyka
  • Ori Burg
    January 2, 2010 at 6:54 pm
    If I will make my footage a JPEG-Sequence it should fix it?
    thanks
  • Walter Soyka
    January 2, 2010 at 7:27 pm
    [Ori Burg] “If I will make my footage a JPEG-Sequence it should fix it?”
    It’s the first thing to try. Native HDV footage seems to cause all kinds of bizarre behavior in AE.
    The second troubleshooting step is making sure OpenGL is disabled.
    Walter Soyka
  • Tim West
    January 3, 2010 at 11:20 am
    Guess you have probably already tried this but how about purging your video cache, closing down all composition windows and rendering with caps lock engaged?
    Will trashing your AFX preferences file help?
    Good luck.
