computer patrs
Posted by Damian Bochenek on January 30, 2014 at 7:23 pmHi guys!
I want to set up new PC specially for making movies in Sony Vegas 12. I need a help in choosing best parts in my money limit (about 1200-1500 $) whithout monitor. I’m from Europe and i thinking about buy everything in USA because there is cheaper parts.
Stephen Crye replied 12 years, 8 months ago 3 Members · 3 Replies -
Stephen Crye
January 30, 2014 at 7:58 pmJohn Rofrano recommended https://www.iBuyPower.com .
Steve
Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
Dave Osbun
January 31, 2014 at 1:55 pmStart out by getting the fastest Intel i7 Ivy Bridge CPU and work down from there. For motherboards, look for one that has 4, at a minimum, SATAIII ports (6 gb/s), and 8gb RAM. There are quite a few good SSD drives, and you can’t go wrong with the Samsung 840 Pro (500gb minimum). Video card is your choice, but you should be able to get an upper-end nVidia or ATI Radeon card within your stated budget.
Most importantly, DO NOT SKIMP on the power supply! Get a BRAND NAME unit, 800 watts MINIMUM. If you get a cheap, no-name power supply, you’ll run into issues down the road with system stability and pull your hair out troubleshooting.
Personally, I order all my stuff from NewEgg. Prices are good and no hassle returns.
Dave
Stephen Crye
February 1, 2014 at 3:23 amBefore you buy the Samsung 840, read this torture-test report.
I was about to buy the Samsung until I read it. The Samsung, although probably useable, did not fare will in the group. After reading it I got a Corsair Neutron 480 GTX.
https://techreport.com/review/25681/the-ssd-endurance-experiment-testing-data-retention-at-300tb
The Neutron seemed to have a good, steady performance. The Samsung read-times graph was all over the place.
Steve
