Activity Forums Avid Media Composer Computer Monitors Blinking!!!!!!!!!
  • Computer Monitors Blinking!!!!!!!!!
    Posted by David Weldon on June 15, 2006 at 4:59 am
    I’m using a dell w/ two 19″ dell monitors, running on xpress pro hd. The right monitor will just go to sleep whenever it feels like it (1 min., 5 min., 15 min., etc.) and the left one will flash in and out to black and back while using media player in the right monitor. I can’t spend another day turning monitors off then back on to get them to come back on! Never had this problem with other monitors before…..PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!
    David Braswell replied 20 years, 3 months ago 2 Members · 1 Reply
  • David Braswell
    June 20, 2006 at 5:38 pm
    Things to check:
    1-Verify you’re using an Avid recommended video card, or at least something in the Quadro family.
    2-Verify display settings to ensure they match Avid recommendations listed in the Readme accompanying every software version.
    3-Make sure “full screen” video is disabled for both video cards. This setting is in the advanced section of display settings.
    4-Make sure all Power and monitor settings dealing with “sleep”, “hibernate”, or “standby” are disabled. If your monitors are disobeying orders not to go to sleep you have bigger issues.
    5-If possible, borrow a “known good” pair of monitors to swap for yours. Also you might try your monitors on another computer.
