Activity Forums Adobe After Effects Expressions computer loading icon(circle)
  • computer loading icon(circle)
    Posted by Barry Suydam on January 18, 2012 at 6:20 pm
    I am trying to replicate the loading Icon seen on computer pages as they are loading. Banging my head against a wall. I need an opacity expression that will allow me to rotate a line past circles in a circular formation that will as the line passes bring individual circles to full opacity as it passes and fade as it goes away and so on and so forth. Cant find any tutorials..have tried amillion things and i am frustrated any help would be much appreciated
    Barry Suydam replied 14 years, 8 months ago 2 Members · 2 Replies
  • Jamie Fraser
    January 19, 2012 at 12:22 pm
    If you don’t need it to be ‘dynamic’ (as it’s not actually loading anything in real time), then you don’t need it to be expression driven. It is certainly achievable with expressions, but if I were you I would just keyframe it.
    Simplest way would be to create keyframes for one circle, going from 0% opacity to 100% and back again. Then copy and paste those keyframes onto each of your other circles, moving the start point for each subsequent layer’s keyframes forward by a frame or two (depending on the speed you’d like it to appear to rotate.
    If you do this in a sub-comp, you can monkey around with the timing (perhaps making it look like it slows down slightly, then speeds up towards the end, so it’s more natural) using Time Remapping on the sub-comp.
    Hope that helps! 🙂
  • Barry Suydam
    January 19, 2012 at 1:33 pm
    I appreciate the response I will give it a try.
