Activity Forums AJA Video Systems Computer display goes BLACK ?
  • Computer display goes BLACK ?
    Posted by Ben Cheng on May 4, 2005 at 10:58 am
    Hi guys
    Wonder if you guys experienced this before ?
    During FCP capturing + rendering + AfterEffects rendering, the computer display goes black
    After a while, the display returns but the system hang
    * Note : all Energy Saver or Screen Saver setting is turned OFF + NO Hot Corner activated
    Configuration :
    PowerMac G5 Dual 2.0Ghz
    4GB RAM
    AJA Kona 2 + K-BOX
    ATTO UL4D
    Huge U320RX-1600DM
    23″ Cinema Display
    OS X 10.3.9
    FCP HD
    QuickTime 6.5.2
    Kona 2 1.1 driver
    * Note : This issue occur before the OS X 10.3.9 + Kona 2 1.1 update
    Cheers
    Ben
    Ron Thompson replied 21 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    May 4, 2005 at 11:12 am
    Not ever really seen this, but it’s most likely an OS or hardware problem, not an FCP/AE problem… Try resetting your PMU switch. Unplug your Mac from Power first…
    The switch is under the removable fan which is over the RAM chips. It’s a small round button. Just push it and wait a minute or two, then restart. What it does is reset power management system wide, and zaps the PRAM.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ron Thompson
    May 6, 2005 at 6:19 pm
    I had this problem for 4 months before I figured out my displays were dying a slow death!! Are you using CRT monitors?
    I replaced both of my CRT’s with two Dell 2001FP LCD displays. Best investment this year! They are in the $700 range, but if you catch them on sale at the Dell site, you can scoop them up for around $600.
    The monitors are an editors BEST FRIEND!!!! Composite, S-Video, DVI, and VGA, PLUS Picture in Picture!! You can’t beat this setup if you need extra monitors for Waveform/Vector scope or Monitoring other sources. Crisp, clean image, and a 1/4″ of the footprint. I haven’t had that problem since installing the Dell’s.
    Before I trashed my CRT’s I swapped out motherboards, swapped display cards, reinstalled OS’s and software, checked power settings and power hardware, and all the while that wasn’t it. If you’re like me, you probably leave your displays on all the time. I guess 5 years of this was enough for my NEC’s.
    Good Luck
    Ron
