Activity Forums Adobe After Effects Compsiting with AE, Lightwave and HDV
  • Compsiting with AE, Lightwave and HDV
    Posted by James Huenergardt on April 14, 2006 at 10:13 pm
    I’m creating a 3D CG background in Lightwave and I will be compositing a keyed out presenter on top of that CG background in AE.
    I’m using HDV footage with the Cineform plug-in.
    In AE, my comp size is 1440 x 1080 1.33 16:9 aspect ratio.
    However, if I render out an image from Lightwave, and bring it into my comp, it looks squished.
    1440 x 1080 1.33 aspect ratio are my settings.
    I tried making it 1920 x 1080 using 1.33 aspect ratio, and it looks fine.
    Is this correct? It’s a bit confusing for a new guy in the HDV world.
    Jim
    Reel Inspirations
    Kipp Crawford replied 20 years, 5 months ago 2 Members · 1 Reply
  • Kipp Crawford
    April 17, 2006 at 7:09 pm
    You simply need to press the Pixel Aspect Ratio Correction button at the bottom of your comp window. It’s the one that looks like a rectangle with two arrows above it.
    -Kipp
