Activity Forums Adobe After Effects Comps within Comps
  • Comps within Comps
    Posted by Adam Taylor on April 26, 2009 at 10:13 pm
    I have a feeling the answer to my question is NO, but its worth asking anyway….
    Working on a project recently, when doing multiple sky replacements i found myself having problems lining things up how i wanted. The reason was that the sky i had created was in a comp (because i used several lens flares to simulate a sun, graduated background, colour tints, fractal noise clouds,etc), and for each shot i needed to reposition the sun to match up with the on-set lighting.
    so for the question… Is there a way to adjust the layers of a nested comp whilst watching the overall project output?
    Every time i had to alter my sun position, i found i had to open the comp, guess roughly where i thought it needed to move, then jump back to the main comp check it, refine it….a long and arduous task when there are lots of shots to do.
    It strikes me that this is such a no-brainer that there must be a way to do it and i’m just too dumb to figure it out.
    regards
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    Stuart Elith replied 17 years, 4 months ago 4 Members · 4 Replies
  • Paul Hennell
    April 26, 2009 at 10:37 pm
    Depending on which AE version you’re on, this might work differently – but there should be a little padlock symbol in the viewer window (On the top tab) which enables you to ‘lock’ it to its current view. So in the main comp lock the viewer, then enter the nested comp and edit away. You can also the window menu to add both comp viewers, so you can see what your doing in the nested comp as well as the parent.
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
  • Martin Earle
    April 26, 2009 at 10:40 pm
    Dear Adam,
    If I remember correctly you can find the answer by watching this tutorial-
    https://www.videocopilot.net/tutorials/magic_glass/
    after a while he explains how to watch two comps at once to make accurate adjustments. if you’re patient you’ll find out how!
    Martin
  • Adam Taylor
    April 26, 2009 at 10:42 pm
    why thank you both for such quick responses.
    I was right…too dumb to figure it myself!
    cheers
    Adam
    Adam Taylor
    Oldham, UK
  • Stuart Elith
    April 27, 2009 at 4:51 am
    A nifty shortcut for this kind of workflow is Cmd+Option+Shift+N (on mac).
    It creates a new comp viewer next to the current one and locks it. So you don’t have to go through the menu for a new viewer, then lock it and dock it. Nice!
