  • Posted by Marc Lucas on June 6, 2011 at 7:34 pm
    If I duplicate a Comp then make changes to the comp the original comp gets changed to. Can I not just duplicate a comp and make it say version 2 and make slight changes so I have two different versions? I know I can copy the layers and then put them in a new comp and that won’t effect this it just seems a bit strange the way it works.
    Marc Lucas replied 15 years, 3 months ago 2 Members · 2 Replies
  • Todd Kopriva
    June 6, 2011 at 8:56 pm
    There’s a difference between duplicating a composition in the Timeline panel and duplicating a composition in the Project panel.
    If you do it in the Timeline panel (which I suspect you are), then you’re not really duplicaitng the composition; you’re duplicating the precomposition layer. The new layer and the old layer both point to the same source item—a single composition.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Marc Lucas
    June 6, 2011 at 9:39 pm
    Sorry I didn’t word the post correctly, yes I was meaning when I duplicate a pre-comp.
