Activity Forums Apple Final Cut Pro Legacy Compressor’s length of time to process
  • Compressor’s length of time to process
    Posted by Joe Orange on April 25, 2010 at 3:43 am
    Can anyone put their finger on why 2 very similar Macbook Pros should take such different length of times to process a 5D clip (from 30 to 25fps) with exactly the same settings. We’re talking 3 minutes vs 1 hour. Obviously, both Macs in proper working order etc etc
    Does it make any difference whether the external drive used is mains powered or not to performance?
    Joe Orange replied 16 years, 5 months ago 2 Members · 2 Replies
  • Zane Barker
    April 25, 2010 at 6:25 am
    You say vary similar but you tell us nothing about the configuration and set up of each machine.
    For each machine give us specific info.
    Proceesser speed
    Amount of ram
    Is e media on the system drive or external
    If external how is it connected
    Is there a virtual cluster set up in qmaster
    What version os
    What version of compressor
    What format video is the original video
    What format are you compressing to
    With more info mabie we can answer your question
    Hindsight is always 1080p
  • Joe Orange
    April 26, 2010 at 12:44 pm
    Ok here goes –
    2.33 vs 2.4 Intel Core 2 Duo
    3 GB vs 4 GB RAM
    External drives used in both cases via FW800 – although one not mains powered
    What is a virtual cluster and how do I know if I have one?
    OS X 10.6.3 vs 10.6.2
    Compressor 3.5.2
    H.264
    Apple ProRes 422 HQ
    Managed to narrow it down to putting Frame Control – On and beyond being where the time remaining becomes hours instead of minutes but the difference is plainly too much even allowing for the difference in specs.
