Activity Forums Apple Final Cut Pro Legacy Compressor won’t open!
  • Compressor won’t open!
    Posted by Kenny Powerass on September 6, 2006 at 3:22 am
    I have a new 17″ MacBook Pro attached to a newly purchased refubished 30″ HD Cinema Display.
    I recently installed Final Cut Studio, but the installation was interrupted. I think I had to skip Motion and maybe Soundtrack Pro.
    I was able to use Final Cut Pro, Compressor and DVD Studio Pro to do some edits and make a couple of DVDs.
    Then one day I tried to export from FCP to Compressor and I got a never-ending spinning beach ball. I’ve gotten the same result every time since then. I even tried to wait it out, but hours later it was still hung up.
    To troubleshoot I tried to open Compressor on its own. The icon bounces in the dock for 3-4 seconds as if it’s opening and then it stops and pretends like it never happened.
    I uninstalled Final Cut Studio as best as I could and re-installed it completely. Everything else seems fine, but Compressor still doesn’t open.
    My Cinema Display has been acting funny – not always waking from sleep. So, I tried Compressor with the display unattached – same result.
    Repaired permissions – no dice.
    Any advice?
    As always, there’s a deadline looming.
    Kenny
    Jeremy Garchow replied 20 years ago 2 Members · 5 Replies
  • Jeremy Garchow
    September 6, 2006 at 3:32 am
    Have you ran a software update to update your apps to the latest versions?
  • Kenny Powerass
    September 6, 2006 at 6:14 am
    Yes, I updated everything to the latest versions and installed the Pro Apps Update.
  • Kenny Powerass
    September 6, 2006 at 6:18 am
    I also should mention that if I do a search in the Finder window that it never finds anything – the indicator just spins and spins. This started vaguely around the same time as my Compressor issue.
    I believe the problem is somewhere besides Compressor itself.
  • Kenny Powerass
    September 6, 2006 at 6:38 am
    I also zapped the PRAM – still no luck.
    I logged in as another user – same result.
  • Jeremy Garchow
    September 6, 2006 at 1:33 pm
    If your system is running funky, it might be time for a full reinstall from the ground up.
    This has nothing to do with your display.
    Jeremy
