Activity Forums Apple Final Cut Pro Legacy Compressor won’t launch
  • Compressor won’t launch
    Posted by Robert Douglas on April 2, 2007 at 5:37 pm
    Compressor 2.3 will not launch from within FCP. Under the export choices, compressor is grayed out and not an option. Compressor will not launch from the applications menu either. Compressor 2.3 shows as 83.7mb size app with no obvious wierdness. I am not sure how to uninstall and reinstall. I am using FCP 5.1.4, tiger, G5 8 gigs of ram, Decklink HD pro Dual card.
    Any help would be great.
    Robert
    Jeremy Garchow replied 19 years, 5 months ago 3 Members · 9 Replies
  • 9 Replies
  • David Roth weiss
    April 2, 2007 at 6:34 pm
    Robert,
    Compressor has prefs just like FCP and all the other apps. They are most likely corrupt and in need of trashing. You can find them in the library… That’s what I’d be looking at first before a new install.
    DRW
  • Robert Douglas
    April 2, 2007 at 6:43 pm
    Hi David,
    If I go to user/home/library/application support/compressor, there is a lot of stuff in there. What am I looking for to trash? And what do I not want to mess with.
    Robert
  • David Roth weiss
    April 2, 2007 at 7:08 pm
    Can’t help ya there… I’d copy them all to another place for safe keeping and then start trying to find the right one by trial and elimination.
  • Robert Douglas
    April 2, 2007 at 7:48 pm
    David,
    Thanks for the insight, I will give it a shot.
    Robert
  • Jeremy Garchow
    April 2, 2007 at 8:28 pm
    NO!
    DOn’t touch anything in that folder.
    TO trash Compressor preferences, you want User > Library > Preferences > com.apple.compressor.Compressor.plist
  • Robert Douglas
    April 2, 2007 at 9:15 pm
    Hi Jeremy,
    I still have all of the compressor application support files intact. I moved the compressor preferences to the trash to take it offline yet compressor still will not launch. I am considering uninstalling, but I am not sure what Final Cut Studio disk has compressor on it. I did the upgrade from FCP 5 to FCP 5.1.4. Still messing with it, any ideas would be great.
    Robert
  • Jeremy Garchow
    April 2, 2007 at 11:49 pm
    Use the FCP install disk, do a custom install and choose only compressor.
    Jeremey
  • Robert Douglas
    April 3, 2007 at 1:45 am
    Jeremy,
    Thanks, I did that and problem solved.
    Robert
  • Jeremy Garchow
    April 3, 2007 at 3:14 am
    Cool.
    Glad you are up and compressing.
    Jeremy
