Activity Forums Apple Final Cut Pro Legacy Compressor won’t function
  • Greg Strange
    April 5, 2008 at 11:28 am
    Chris, I have had the same problem. Compressor would launch but the batch window wouldn’t open so it was useless. Then after multiple (manual) de-installs and re-installs, Compressor crashed on open every time.
    I’ve been all over the Creative Cow boards, the Apple boards… I’ve tried a half dozen things dozens of times… been working on this for HOURS. Nothing has worked. Then I came across your post. It was my last ditch effort to get Compressor working again and by God it worked! THANK YOU!
  • Robert Berg
    November 4, 2008 at 8:29 pm
    After deleting and re-installing everything as dictated in Apple’s Compressor Troubleshooting Basics, I still got no batch screen until I read and did the following.
    In some cases after updating or reinstalling Compressor 3, the Preview window may display a large blank space in the upper area of the window.
    Take the following steps to remove the blank space from the Preview window.
    1. Choose Window > Layouts > Standard 1280×800.
    2. Close Compressor.
    3. Open Compressor.
    After taking these steps, the Compressor Preview window should appear without the blank space.
    This is what fixed it for me. Cheers.
  • Mandy Tsema
    April 22, 2011 at 2:56 am
    I have compressor is running half way but new batch window is not opening same problem as you had.
    If i uninstall FCP6 and reinstall it then how would that be effected to my footage? I have almost 15 hours footage which I don’t want to delete.
    Help please
Page 2 of 2
