Activity › Forums › Apple Final Cut Pro Legacy › Compressor won’t compress
  • Compressor won’t compress
    Posted by Walter Miale on November 22, 2007 at 2:04 am
    OK, it’s Thanksgiving eve, deadline imminent, and I’m stalled. Is anybody out there?
    Running FCP 5.0 on a new imac. Using Compressor for the first time. I’m in FCP, and select a simple 2-minute sequence in the browser, or click on the timeline of a simple 2-minute sequence. Go to Export thru Compressor. Set the settings and destination. Acceptable filename for the output file. Click submit. On occasions when the app doesn’t crash (it crashes when the batch monitor is clogged with sequences I tried to submit and won’t unclog) nothing happens. If something turns up in the batch monitor, it claims to be processing, but doesn’t move beyond zero complete. Usually then, it won’t let me delete it from the batch monitor.
    Thanks.
    Walter M
    Rafael Amador replied 18 years, 10 months ago 3 Members · 3 Replies
  • Don Greening
    November 22, 2007 at 4:28 am
    Until you get it figured out try exporting a reference or self-contained QT movie and use Compressor as a stand alone app. See if that solves it.
    – Don
  • Walter Miale
    November 22, 2007 at 7:03 am
    Will do, Don. Thanks.
  • Rafael Amador
    November 22, 2007 at 10:17 am
    If its keeps crashing, have a look to see if you have the Qmaster for your Compressor version.
    Rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
