Activity › Forums › Compression Techniques › Compressor Watermark and Text Overlay Problem
  • Compressor Watermark and Text Overlay Problem
    Posted by Brian Steele on April 13, 2012 at 1:54 am
    Hi all,
    I’m new to the community, so bare with me as I’m getting used to the social norms of creative cow.
    I’m working with compressor version 3.5.3, and the quicktime I have imported is Avid DNxHD Codec, 1920×1080, 23.98 fps. I created a text with no background (alpha) in photoshop. After importing the QT, I applied my custom setting (H.264 for high-bandwidth connections, 640×360, data rate: 0.819 Mbps). I went to filters in Compressor, and checked watermark, then chose my photoshop image. It displays fine in the preview monitor, but when I hit submit, the end result is a QT with the watermark over a very dark still image of the first frame of my original QT. I tried doing a text overlay, and the same issue occurred. I also tried a random other setting (JPEG 100 NTSC), but that had the same result.
    The QT compresses perfectly fine if I don’t apply a watermark or text overlay, so obviously something is going wrong in this step of the process. Any ideas or advice is greatly appreciated. Thanks!
    Dirk Westervelt replied 13 years, 7 months ago 3 Members · 4 Replies
  • Matt Fisher
    September 14, 2012 at 9:47 pm
    Brian,
    I am having the same exact problem and I’ve been unable to find any solutions online.
    Have you had any luck figuring this out since april?
  • Dirk Westervelt
    January 31, 2013 at 6:59 pm
    Hi Matt, Brian,
    We’re having this issue too. Did either of you ever find a solution?
    -d
  • Matt Fisher
    January 31, 2013 at 7:05 pm
    Unfortunately no, I gave up and just added another step where i create a pro-res mezzanine file from the dnxhd master.
    I then do the alpha overlay to the pro-res file which works wonderfully.
  • Dirk Westervelt
    January 31, 2013 at 9:20 pm
    Thanks Matt! Good to know.
    -d
