Activity Forums Compression Techniques Compressor vs Sorenson Squeeze
  • Compressor vs Sorenson Squeeze
    Posted by Nathan Grout on October 13, 2010 at 3:14 am
    Ok. Let’s duke it out. If you have used both Compressor and Sorenson Squeeze, I want to hear from you. I know that if you have a favorite and I ask which is better, you will simply suggest your favorite, so I’ll be more specific in my questions. Compressor fans: why is Compressor good enough or even better than Squeeze? Squeeze fans, why is it worth shelling out the extra $800 for Squeeze instead of settling for Compressor? I am more interested in the strengths of each software than the perceived weaknesses of the other.
    If it helps, I am interested in compression of all types, but specifically compression for web and compression of editing friendly formats, especially those of the ProRes family.
    Nathan
    PS I understand that there is probably already a host of threads responding to these issues, but my searching for the past 20 minutes has been in vain, so please feel free to respond with links to other threads.
    PPS Is there another software package I should consider?
    Craig Seeman replied 15 years, 11 months ago 3 Members · 6 Replies
  • Craig Seeman
    October 13, 2010 at 4:40 am
    [Nathan Grout] “PPS Is there another software package I should consider?”
    Telestream Episode. It’s scalable from desktop to enterprise. Support a wide varied of professional codecs , has a great nodal interface, great processing filters, FAST, has a forum on the COW.
    https://realworldvideocompression.com/rwvc/2010/10/4/my-first-look-at-episode-6.html
    https://www.telestream.net/episode/segments.htm
    https://www.telestream.net/episode/overview.htm
  • Rich Rubasch
    October 13, 2010 at 2:53 pm
    Get Episode….Episode with compressor and MPEG Streamclip get you there every time.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Nathan Grout
    October 13, 2010 at 5:46 pm
    Rich, would you elaborate? What does Episode add to the mix that Compressor and MPEG Streamclip can’t do?
  • Nathan Grout
    October 13, 2010 at 11:36 pm
    I’m also interested in knowing about your experiences with Episode’s “One Click Clustering™”. Have you had good results? Is it more stable than Qmaster clusters?
    Nathan
  • Craig Seeman
    October 13, 2010 at 11:39 pm
    Episode uses MainConcept H.264 codec which is major better than Apple’s H.264 codec (maybe one of the worst H.264 codec out there).
    Episode has excellent processing filters.
    Episode supports more codecs in and out.
    Episode is fast.
    Episode 6 Pro can now do parallel encoding.
    Episode can be scaled up to the “enterprise” level.
    Episode’s Monitor function is more flexible than “Droplets.”
  • Craig Seeman
    October 15, 2010 at 5:09 pm
    Look at this testimonial posted in the COW’s Episode forum.
    https://forums.creativecow.net/readpost/232/1273
