Activity › Forums › Apple Final Cut Pro Legacy › Compressor VS. Quicktime Pro
Posted by Lisa Rolley on March 6, 2009 at 5:57 pmHey compression friends : )
SO I usually use QT Pro to ltrbx material that is 1920×1080 which needs to be 720×486.
I noticed recently on an agency’s spec sheet how in compressor when making h.264’s you can preserve color space which qt pro is not able to do – You almost always notice a color shift when encoding to that codec.
SO my question is how can i do that same ltrbxing to 720×486 within in compressor so it is exactly like how QT Pro does it – while also being able to use all the extra tools of compressor – mainly just preserving that color space.
Thank you
Lisa
Llewelyn Roderick replied 17 years, 6 months ago 5 Members · 18 Replies -
Tom Brooks
March 6, 2009 at 6:16 pmUse the Geometry tab in the H.264 preset of choice. There you can crop the source or pad the output dimension. In the drop-down for Source Inset (cropping) there’s a choice for “Letterbox area of source.”
Note that I’m on Compressor 3. Earlier versions may differ. -
Lisa Rolley
March 6, 2009 at 6:18 pmHello
I have the latest version of compressor – so i guess my remaining question is: when i bring a 1920×1080 qt file down to 720×486 all i have to do is ltrbx check to preserve aspect ratio – if i want to EXACTLY match that ltrbxing how would i do so in Compressor?
Thank you
Lisa
Tom Brooks
March 6, 2009 at 6:24 pmYou would set up a custom H.264 preset, using one of the provided ones as a starting point. You’d set the output size (encoded pixels) to 720×486. Use the menu choice I mentioned (Letterbox area of source). This will letterbox the HD material by making its width 720 and leaving black bars at top and bottom to fill out the 486. Experiment with this to see if it gives you the same result.
Lisa Rolley
March 6, 2009 at 7:40 pmI followed your instructions and it made 720×486 but did not ltrbx it…
if you have any other help or if someone else has any idea what i am doing wrong please advise
thank you Lisa
Rafael Amador
March 7, 2009 at 1:05 am[Lisa Rolley] “I noticed recently on an agency’s spec sheet how in compressor when making h.264’s you can preserve color space which qt pro is not able to do – “
Hi Lisa,
Would you mind to post those specs?
Cheers,
rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Lisa Rolley
March 7, 2009 at 1:26 am•Video Compression Type/Codec: H264
•Video Bitrate: 7500 kbits/sec
•Frame Rate: 29.97 fps
•Size: 720×486 (If source material is 720×486)
720×480 (If source material is 720×480)
•Audio Codec: AAC (aka MPEG-4)
•Audio Sample Rate: 48kHz
•Audio Bitrate: 192 kbits/secThe source qt file i have is 1920×1080 full resolution / quality and normally i would just use qt pro to do the ltrbx and h.264 conversions but i would really like to try out the option in compressor which allows for preserving the color space…its a very noticeable color switch when its converted in qt pro.
Thanks for your help i look forward to getting your advice on how to make this happen properly in Compressor – again i want to match the specs and ltrbxing that qt pro does but while preserving color.
Best
Lisa
Rafael Amador
March 7, 2009 at 2:15 amHi Lisa,
The problem of QT is that you have little control on any process.
In Compressor you know that any process will be done in 32b Floating point as long as you set “Frame Control: ON”. Also you can decide the quality of the filters.
In QT you have nothing like that. The pipe-line is quite little transparent.
With QT Player you have no way to control any of those processes. You need to do it through FC (that in the end is just a QT interface).
If you set FC properly, will do the same job than Compressor and faster.
Do the downscaling in a 10b time-line. Set “Renderall YUV in High Precission” and “Render Motion Effects: BEST”. Export a high quality .mov and the send it to Compressor just for the transcoding to H264.
About the specs that you send, I think that the data rate (7.500 Kbps) is huge for an SD movie.
Lisa Rolley
March 7, 2009 at 2:22 amwait i dont understand how to do the ltrbxing process to match what qt pro does…
The specs are what the client is requesting so i have to follow it/
thanks
lisa
Rafael Amador
March 7, 2009 at 2:37 amJust drop your HD clip in and 4×3 sequence and you will get it letterboxed.
Compressor is great but not the best application for geometry changes.
Tom Brooks
March 7, 2009 at 3:26 am
