Activity Forums Apple Final Cut Pro Legacy compressor vs quicktime conversion
  • compressor vs quicktime conversion
    Posted by Judas Beast on July 12, 2007 at 2:45 pm
    I’ll run past my experience so far step by step, it may shed some light on what i need to work on – but I’m having a really hard time getting crisp movs using compressor.
    1 – I’m working with PAL compositions created in After effects (720×576)- rendered out as lossless uncompressed animation quicktimes… look great in quicktime player although typically squashed due to pixel ratio
    2 – I import the lossless animation into FCP, it looks fine and sharp on the timeline, making sure sequence settings use animation codec (forgot to change this from DV before and animation looked rough in the viewer)
    3 – from FCP file menu: export using “quicktime conversion”, I then choose the pre-set: “broadband high”, click the options and the default compressor quality is “high” and set to “H264”. Data rate I set limited to around “150 kbits/sec” (i used to leave it set to “672 kbits/sec” as default but found by lowering this value i got much smaller file sizes without much loss of quality) – frame size is set by default to: 480×360, I leave this alone.
    5 – now trying to use compressor – mimicking the pre-sets that previously worked well with quicktime conversion. I click on source setting and select pre-set: “web download, quicktime 7 compatible 800kbps” I have experimented with limiting data rate from 672 to 150 kbit/secs, also i check frame size – set by default to 480×360, i leave this
    The trouble is results in compressor are just plain worse than before using FCP’s QT conversion – I have no idea if there is some sort of small box I need to tick or un-tick, the original uncompressed file looks crystal clear… I’m slowly going mad here – cant see why it would look so much worst in compressor apparently using the same settings as quicktime conversion?
    um, yeah!
    Judas Beast replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
