Activity › Forums › Apple Final Cut Pro Legacy › Compressor turns just a couple TIFFs fluorescent green
  • Compressor turns just a couple TIFFs fluorescent green
    Posted by Jordan Pool on April 24, 2009 at 3:05 pm
    Hello I just finished exporting my project from the latest version of final cut to compressor, timelin.
    All the video is h.264 video at 1920×1080 and there are about 250 high res stills in the project.
    After sending to compressor and compressing with the h.264 setting at 1920×1080 it seems to make about 5 out of the 250 photos turn a fluorescent green color. Just wondering if its something im doing wrong or if theres someone else whose experienced this problem.
    Thanks in advance!
    Jordan
    Rafael Amador replied 17 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    April 24, 2009 at 3:35 pm
    Hi jordan,
    try replacing the TIFFs by PNGs.
    rafael
    http://www.nagavideo.com
  • Jordan Pool
    April 24, 2009 at 3:36 pm
    Thanks for the quick response, just the TIFF’s that turned green or do you suggest replacing all of them..
    Thanks again
  • Jordan Pool
    April 24, 2009 at 4:06 pm
    ahh ok im semi new to final cut pro still learning obviously.
    I was having trouble earlier when i was dropping my video into my timeline, FCP was telling me that i should match up my timeline settings to my clips setting and I just hit ok so it would do it for me and it changed my compression settings to h.264. Well I had aton of trouble obviously and couldnt get anything to work. I changed my timeline compression setting to dvcpro hd 1080p and everything seemed to work fine.
    When i right click my raw captured video file and hit get info it says the codecs are H.264, Integer Little Endian. I did not capture this video but was given the files on a hard drive…
  • Tom Matthies
    April 24, 2009 at 4:09 pm
    Also make sure that the tiff’s aren’t actually CMYK rather than RGB format.
    Tom
  • Rafael Amador
    Hi Jordan,
    As Dave points h264 is not too editing friendly and seems that can produce very estrange effects in FC.
    I heard that plays fine in the time-line but the behave is unpredictable when you mix it or apply effects.
    Try replacing the green Tiffs by PNGs. No need to change all.
    rafael
  • Jordan Pool
    April 24, 2009 at 4:28 pm
    Hey dave, i typed out a reply a few minutes ago but havent seen it pop up yet so ill try again
    Timeline is set to dvcprohd1080p
    My raw videos when i right click get info they say that the codecs used were h.264 Integer little endian, sorry if i confused you.
    You are right though i was having major trouble when i first dropped my video into my timeline and fcp suggested changing my timeline to h.264 i of course listened and had major problems so i changed it to dvcpro hd 1080 p and all the problems quit.
    I just thought since my original video was listed as h.264 (before going into fcp) that i could use that setting in compressor but i guess not, im guessing i should have used the same setting as my timeline…
    Thanks for all the help everyone, this is my first time trying this and all of you have been awesome!!!
  • Rafael Amador
    April 24, 2009 at 4:32 pm
    Hi Dave,
    I’m not sure, of course.
    But If I have 250 still in my sequence, and only 5 are giving me problems, I would start by looking if just chaging those pictures is enough.
    If not, i would try to find other workaround.
    Editing in h264 still being a mystery for the most part of the mankind.
    rafael
