Activity Forums Apple Final Cut Pro Legacy Compressor transcoding and FCP 5 problem
  • Compressor transcoding and FCP 5 problem
    Posted by Vince Sanchez on June 2, 2005 at 10:14 pm
    I have been testing files for transcoding using compressor.
    Iam starting with an NTSC DV video file and in compressor using
    the advanced setting to transcode to PAL. The movie transcodes fine and
    in the quicktime player info box it shows the correct settings for PAL, size
    and frame rate. When I import this file into FCP5 andput it on a timeline
    it shows that it needs rendering. In the items info it says that the file
    is 29.97 frames per second. Any else tried this kind of transcoding with better luck?
    Thanks for any info.
    Vince Sanchez replied 21 years, 3 months ago 1 Member · 1 Reply
  • Vince Sanchez
    June 3, 2005 at 6:49 am
    For anyone else who may be having this problem. It seems you have to change the settings in the frame controls, it doesn’t seem to matter exactly what you change, and then the files are read correctly in FCP.
