Activity Forums Apple Final Cut Pro Legacy compressor to iDVD
  • compressor to iDVD
    Posted by Richard Blakeslee on May 18, 2005 at 7:42 pm
    It seems like I’ve read these threads a million times. I still can’t get iDVD to import my finished movie from Compressor. I’m using, MPEG-2 60mm High Quality encode widescreen. I’ve folowed the threads info and have the preset set up right. I get the movie and the soundtrack. Looks and sounds great. (a MiniDV 5 min show in 16:9 rendered out at 8 bit, export qtmovie, 720×480 NTSC DV (3:2), pixel aspect NTSC- CCIR601/DV anamorphic 6:9 checked, fileld dominance lower, editing time base 29.97, compressor-uncompressed 8-bit 4:2:2. I save as self-contained unclicked–drag to Compressor)
    Try to import in Compressor–nothing. or ‘Unsupported File Type, Invalid Video’
    I can drag the ‘un-selfcontained’ FCP movie to Compressor and it works great. Only the movie is 6.27gigs–so I thought I should use Compressor. I’m guessing that I need better software then iDVD. DVD Studio Pro–but that’s over $400. and I only do a few DVDs a year.
    Can one import movies that have been compressed with Compressor into iDVD?
    Richard
    G4, dual 1gig, 10.2.8, 1 gig RAM, FCP 4.1, Compressor 1.1
    Jeff Carpenter replied 21 years, 4 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    May 18, 2005 at 8:47 pm
    Don’t use Compressor at all. iDVD does that for you.
    Just save your movie as a Quick Time movie and drag that into iDVD. (Check the iDVD preference settings first to make sure it will compress it the way you want before you drag it in.)
    I’m fairly certain that you can simply “Export” as a QT movie with “Make Self-Contained” UN-checked and that will work. (If it doesn’t, use the “Quick Time Exporter” to make a file. That’s not as good, though, so try the other way first.)
