Activity Forums DVD Authoring Compressor to DVDSP
  • Compressor to DVDSP
    Posted by James Dow on February 9, 2009 at 3:10 pm
    I edited an FCP sequence at 23.98 FPS, set a custom compressor setting to change bit rate, also set to 23.98 fps, is there anywhere in DVDSP setup that I need to indicate the 23.98 frame rate? When I import the asset, it is sayiny its a 29.97 track.
    James
    JPD
    James Dow replied 17 years, 6 months ago 2 Members · 2 Replies
