Activity Forums DVD Authoring Compressor to DVD Studio Pro (compressor fails)
  • Compressor to DVD Studio Pro (compressor fails)
    Posted by Terry Brown on April 12, 2010 at 7:45 pm
    Recently (I think right after I upgraded to Leopard) Compressor stoppe working. Is there a solution (in MPEG Streamclip or FCP) so that I may import into DVDSP?
    Terry Wilson replied 15 years, 11 months ago 2 Members · 1 Reply
  • Terry Wilson
    September 12, 2010 at 2:24 pm
    dunno what sort of quality requirements you are looking for, but couldn’t you export a loss-less animation file from FCP and use DVDSP’s encoder? The quality is about as good as compressor was (yes compressor is mostly broken).
    If you do this however, encode the audio separately, use compressor to make ac3 files, it still works for that. ac3 are a much lower bit-rate, allowing you to almost double your video bit-rate.
