Activity Forums Compression Techniques compressor to dvd issue
  • compressor to dvd issue
    Posted by Jason Zaloga on October 29, 2010 at 9:26 pm
    video is ntsc 872×486 widescreen i chose square pixals for par.
    when i bring it into compressor i used the preset dvd best quility 90 minutes.
    inspector settings:
    mpeg-2 ntsc,16:9 video sd format
    quality-two pass vbr best average bitrate 7.0,max 8.2,motion best,gop ip 15 and for the cropping i left alone: source top 4-bottom 2 output: top 6-bottom 5. everything seems to be fine in the before and after preview window. but once it’s on dvd and i watch it on tv it is squashed a bit.
    i tried the 16×9 1.33:1 in the cropping part of inspector and that what happened. it seems the settings are different from AE to PR. how can i fix this. is this a compressor setting issue or the source files themselves?
    Jason Zaloga replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
