Activity Forums Apple Final Cut Pro Legacy Compressor Timecode Generator Filter problem- creates black clip with timecode
  • Compressor Timecode Generator Filter problem- creates black clip with timecode
    Posted by Inbal Lessner on October 2, 2012 at 11:28 pm
    Hi all,
    I actually use Avid MC for my editing work, but use compressor for encoding to Vimeo/DVD/Blu-Ray – never had this problem before.
    I have a QT ref file (HD 23.98), which I import into Compressor and trying to burn a DVD with burn-in timecode.
    The overlay looks fine in the Preview window, but when I encode to any format (QT/DVD) all I get is a black clip with running timecode.
    I can render a self-contained QT with the timecode overlay in the Avid, but I prefer not to tie up my editing system with the render, if I can have Compressor do it while I work.
    Any ideas?
    David Glasgal replied 13 years, 4 months ago 3 Members · 2 Replies
  • Dan Lebental
    October 28, 2012 at 9:35 pm
    I am seeing the exact same thing. My workflow is similar. I export QT reference file from the MC. I import to compressor and render out Quicktime movies in H.264 so I can pass through timecode(which is critical for my uses). So when I put the TC burn in filter in Compressor it renders black. Ugh
    I would use Sorenson Squeeze but it cannot pass through timecode which is ridiculous.
    Another alternative is to use CatDv -$99. Which can carry timecode and do burn ins while transcoding from QT ref.
    Dan Lebental ACE
  • David Glasgal
    May 4, 2013 at 1:20 am
    anyone ever figure this out? i’ve been using compressor for years doing this and just got this problem with an avid output batch that i’m doing bitc for. what’s up
