Activity Forums Compression Techniques Compressor Temporary Files?
  • Compressor Temporary Files?
    Posted by Evan Cox on August 23, 2013 at 5:56 pm
    I have sort of a general Apple Compressor question. Every time I compress a video it begins to drain memory from my local hard drive. I have three other hard drives with more space that I would rather use. I have looked multiple times as far as I could to find where these temporary compressor files are hiding but I can’t find them anywhere! They are taking up quite a bit of space at this point. Any idea where I might be able to find them? Or a better way to start looking for them? Anything helps.
    -Evan
    Paddy Uglow replied 13 years ago 2 Members · 1 Reply
  • Paddy Uglow
    August 27, 2013 at 2:36 pm
    I don’t use Compressor at the moment, but I found out the following:
    One person says “If you click on the blue button on the top right corner of your screen (the one showing a magnifier icon) you can trace this temporary files folder and get rid of it.”
    The other found the files in /private/var/spool/qmaster
    I hope that helps.
    Presumably there are some preferences somewhere where you can set a location for temporary files?
    Good luck
    – Paddy, CreativeMedia.org.uk
