Compressor target size BUG
Hi, I’m having a problem with Compressor: changes made in Inspector to alter the target size (changing bit rate) doesn’t work anymore, meaning the size of the exported file stays the same no matter what I do… Now the first time I tried that it did work, changes in bit rate did affect the final size, but after that first (lucky :)) time it stopped working.
Someone ever had this problem?? any ideas??
thanks!!!
