Activity Forums Apple Final Cut Pro Legacy Compressor stuck on Waiting
  • Compressor stuck on Waiting
    Posted by Wayne Beckwith on May 5, 2010 at 6:05 am
    For some reason compressor just want actually start a project. It’s listed in to do jobs, but just stays on waiting with no progress. I have tried both importing a QT file and sending straight from the TL of FCP.
    I have also tried other files with the same results.
    I am selecting Best for 90Min SD DVD which is what I have always done
    The QT file plays fine so it’s not a file issue.
    Any ideas please?
    regards,
    Wayne
    Rafael Amador replied 16 years ago 4 Members · 5 Replies
  • Jerry Hofmann
    May 5, 2010 at 12:30 pm
    Look in your User Library preferences folder for “com.apple.compressor.Compressor.plist” and trash it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Wayne Beckwith
    May 6, 2010 at 10:03 pm
    Thanks Jerry that did it
  • Julian Semilian
    September 15, 2010 at 2:27 am
    Hello,
    My compressor won’t make PAL files. I am using a MacBook Pro with Final Cut Studio Pro 4.
    Can you suggest a solution?
    All the best,
    Julian
  • Wayne Beckwith
    September 15, 2010 at 2:55 am
    What file format are you trying to output to? If it’s a DVD format, then you don’t select the PAL/NTSC format until you take it to the next step in DVD studio Pro and set the DVD output format in preferences
    Regards,
    Wayne
    Regards, Wayne
  • Rafael Amador
    September 15, 2010 at 11:16 am
    Open the manual and read a bit.
    Rafael
    http://www.nagavideo.com
