Activity Forums Apple Final Cut Pro Legacy Compressor stops during process
  • Compressor stops during process
    Posted by Calebandashley on January 29, 2006 at 6:49 pm
    I am trying to send a sequence (Sony HDV 1080i) through compressor (2.0.1) from FCP (5.0.4) as an MPEG2 (120 min best widescreen) for use on a SD DVD. I’ve tried to send the same sequence several times, but every time it quits on me about half way through. I am desperate and running out of time
    Don Greening replied 20 years, 7 months ago 2 Members · 3 Replies
  • Don Greening
    January 30, 2006 at 4:27 am
    One idea to consider is that you could have a corrupt render file in your timeline, especially since you mention that Compressor is stoppng at the same spot every time. Try trashing your render files including any audio renders and let FCP re-render everything. Then export your finished timline for Compressor and try again. The most reliable way is to export a reference or self-contained movie and then use Compressor as a stand alone app.
    – Don
  • Calebandashley
    February 1, 2006 at 7:41 pm
    Do you mean export as a QT then bring drag the QT into compressor?
    Caleb
  • Don Greening
    February 2, 2006 at 4:16 am
    [calebandashley] “Do you mean export as a QT then bring drag the QT into compressor?”
    Exactly. Or you can just go to Compressor’s file menu and use the import file command. The keyboard shortcut is: Command “I” without the quotes.
    – Don
