Activity › Forums › Compression Techniques › Compressor Settings for MPEG-4
  • Compressor Settings for MPEG-4
    Posted by Joe Pegg on May 5, 2014 at 11:55 am
    Hi everyone 🙂
    I’m using Compressor V3.2.3 and the client has asked me to provide the following:
    MPEG-4
    Container format: .mp4 or .mov (QuickTime H.264)
    Video:
    Bit rate / Quality: 30Mbps CBR minimum / Constant
    Codec: H.264 / QuickTime
    Frame size: 1920×1080
    Frames per second: 25 (progressive scan)
    Audio:
    Codec: AAC
    Channels: Stereo
    Bit rate: 320 kbps
    Sample rate: 48 KHz
    Sample depth: 16 bit
    Using Compressor I can’t figure out how to set it up to provide everything I’ve been asked for.
    Using MPEG-4 as my file format I’m restricted to 2Mbps.
    Using QuickTime with MPEG-4 Codec i can set the data rate to 30Mbps, but not at a constant bit rate.
    Is anyone able to help? I’d really appreciate it. Please let me know if you need any more information.
    Craig Seeman replied 12 years, 4 months ago 2 Members · 2 Replies
  • Joe Pegg
    May 5, 2014 at 4:12 pm
    Just to add, the timeline is ProRes 422 and I have existing QTs exported at source resolution.
  • Craig Seeman
    May 5, 2014 at 4:40 pm
    In order to encode H.264 .mp4 you’d need Compressor 4.
    Compressor 3 only does H.264 .mov (or m4v for iOS devices).
