Activity Forums Compression Techniques Compressor settings for 30 min web videos
  • Compressor settings for 30 min web videos
    Posted by Laura Seltzer-duny on April 21, 2013 at 12:19 pm
    I need to figure out the best Compressor output for 30 minute QT videos to be posted on the web. It’s a series of lectures and they’ll be watched in a small box on a website.
    I’ve been using the following output setting for 16X9 videos that are 10 minutes or shorter and it’s worth giving it a try on your short form videos. However, this is taking way too long for my longer videos.
    Shorter video output setting are:
    Description: H.264 video at 1,000Kbps with AAC 44.1kHz audio
    File Extension: mov
    Estimated size: 460.8 MB/hour of source
    Audio Encoder
    AAC, Stereo (L R), 44.100 kHz
    Video Encoder
    Format: QT
    Width: 720
    Height: 405
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: 30
    Frame Controls Automatically selected:
    Retiming: (Fast) Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Better (Motion Adaptive)
    Adaptive Details: Off
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 50
    Key frame interval: 150
    Temporal quality: 50
    Min. temporal quality: 50
    Average data rate: 1.024 (Mbps)
    Maximum data rate: 1.024 (Mbps)
    Hinted for QuickTime
    streaming server
    Kylee Pena replied 13 years, 4 months ago 4 Members · 3 Replies
  • Jeff Greenberg
    April 21, 2013 at 7:40 pm
    There’s no point in doing VBR if your Average & Maximum are going to be the same. There’s no ‘variable’ in your data rate. At that point, you might just try CBR (Fast, worse quality>)
    Have you considered a hardware encoder?
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Tom Laughlin
    April 23, 2013 at 9:51 pm
    Sometimes, if you have the time, I usually run a test on one minute of video, but running it through 3-5 different compressor softwares. I look at speed of encode, quality, and what control I actually am given inside the encoding software. Run some speed and quality tests, then you know how long a file takes, but checking the info of the file, and the time started or time ended or ‘created’, this will give you a ratio to use for 1 minute, so now, you can predict how long each encoder will take, and also evaluate quality, but normally, quality encodes can take longer regardless the compression software you are using. Bitrate, frame-rate and some other things can be changes to increase speed of encode drastically and not affect quality too much.
    Jan Ozer is the genius of this, and he has a ton of info on-line about tricks you can do to help. I have friends who take frame-rates from 29.97 to 15 or less, and do not see that much of a quality hit, so.
    Hope this helps a little…
    Tom Laughlin
    Producer/Editor
    Digital Chop House
    Salt Lake City, Utah
  • Kylee Pena
    April 25, 2013 at 9:01 pm
    Just wondering, what are the specs for the source file?
    blog: kyleesportfolio.com/blog
    twitter: @kyl33t
    demo: kyleewall.com
