Activity › Forums › Apple Final Cut Pro › Compressor settings for 16:9 PAL IMX
Posted by Fabrizio D’agnano on February 25, 2013 at 11:05 pmHello.
I need to deliver my work in IMX PAL 625/50, 16:9, 720 x 576, aspect ratio 1.78:1.
Source setting is PAL ProRes 1080i. I can export a ProRes file from within FCPX, then create a PAL DV 16:9 project, drag the exported HD clip, and then again export to IMX. I get a correct 16:9 IMX file, so it seems IMX standards admit 16:9 (and the channel specs that airs Disney Channel as well as other important ones requires that setting, so it must exist 🙂 ) . However, I’d like to send the HD timeline to compressor and have it create the IMX file. I can’t export a 16:9 video, even if I choose the 16:9 aspect ratio in the encoder pane. It shows 4:3, or letterboxed at best if I crop or pad. PAL DV 16:9 720×576 produces a correct 16:9 image. What’s wrong in the process?
Thank you.Fabrizio D’Agnano
Rome, ItalyFabrizio D’agnano replied 13 years, 6 months ago 2 Members · 11 Replies -
Francois Jean
February 26, 2013 at 9:25 amAs you know
The normal PAL/DV “pixel aspect ratio” is 1.09, making this PAL file “anamorphic” for supporting 16:9 within this SD format will to change the “pixel aspect ratio” to 1.46, you will still have a PAL 720 x 576 frame but your 16:9 (1.778 image ratio) will be squizzed in the 720×576 (1.25 image ratio).
Real HD is always square ” pixel aspect ratio” = 1 except in some camera codecs like dvcproHD , HDV …
So your ouput will be PAL CCIR 601 / DV (720×576) with a PixelAspedtRation of 1.46 , codec MPEG IMX 625/50 at 50 Mb/s , the remaining question is can you deliver in ” .mov ” or are they expecting full compliance to the imx standard being MXF file with multiple dual mono audio channels.
I did not know how to answer your question , so I hope this can be usefull
all the bestzap
Fabrizio D’agnano
February 26, 2013 at 10:00 amTHank you Zachary.
There’s no problem with the .mov file, I can export the multiple audio channels and so on. I already tried with the setting you suggest, but nothing changes. If I export the same sample using the 4:3 or the 16:9 pixel aspect ratio, the exported file fill show 4:3 in Quick time or on the timeline. This is a screenshot of the settings in compressor:
Fabrizio D’Agnano
Rome, Italy -
Francois Jean
February 26, 2013 at 4:13 pmi have been playing with the same setting and got the same absurd PixRation so I believe you will have to force the right RATIO …
using a custom geometry and custom pixelaspect ratio of 1.46Hope this does perfect (I’m very confident)
regardszap
Fabrizio D’agnano
February 26, 2013 at 4:47 pmThank you!
I will try it now. I hope it complies with the channel standards.Fabrizio D’Agnano
Rome, Italy -
Fabrizio D’agnano
February 26, 2013 at 7:29 pmNo, it seems to produce the same 4:3 file whatever pixel ratio I set. There must be something else. Have you tried it on your side?
Fabrizio D’Agnano
Rome, Italy -
Francois Jean
February 26, 2013 at 11:35 pmHello Fabrizio
I finally did have time to test this and the result are exact the HD is Half …
SD is half : 3×4 anamorphic
and this Normal for PAL SD anamorphic , the HD image is squeezed in the SD frame and it will play in 16:9 in the appropriate viewer and monitor
zapNotaBene:
These screen grab are from footage issued with a book : Craft of the Cut from Marios Chirtou and Mark Riley… -
Francois Jean
February 27, 2013 at 12:58 amAnd in the end , i did use the normal PAL CCIR 601 (16:9) compressor geometry setting and even if it did show a 0.7031 pixel aspect …. i did get the same correct SD squeezed result as the customized 1.46 pixel aspect.
My conclusion is that either way [and i would suggest that you use the PAL CCIR 601 (16:9) setting ] you end up with a correct and standard 4×3 PAL SD squeezed image from your HD images which is what is required.
I am sorry for the “merry go round” but before i had tested all transcoding instead of just looking at the numbers , i had not seen the output clips.
regards
zap -
Fabrizio D’agnano
February 27, 2013 at 10:54 pmThank you.
I don’t know. The image I get exporting IMX 625/60 from FCPX sho6:9, just like the one I used to export from FCP7, shows 16:9in QT Player, FCP timeline, etc. The one I export from Compressor does not. The screenshots you added look like 4:3.
This is exported from FCPX, showing 16:9
This is exported from Compressor, anamorphic 16:9, showing 4:3
This is exported from compressor, padding on.
Fabrizio D’Agnano
Rome, Italy -
Francois Jean
February 28, 2013 at 7:44 amHello again Fabrizio
Your results are looking good. I now believe that only your client can resolve the final choice between SD anamorphic or SD letterbox. (SD anamorphic would preserve the most quality but how your client puts it on air could require otherwise)I have been looking at the “Disney benelux” Delevery specification and the ABC DISNEY Original Production delivery Spec, but i could only find the HD versions in my Archives. I was very much surprised how different the two specs books are : one is Sony codec in MXF and the other is a specific ProResHQ in quicktime. I guess you should require your client’s Delevery specification , here, they only give access to contracted producer or cinematographer through a special internet link …. so I don’t have the SD versions of the specs.
All the best
zap
