Activity Forums Apple Final Cut Pro Legacy Compressor settings advice
  • Compressor settings advice
    Posted by Laura Weinstein on June 22, 2011 at 7:52 am
    Hi, usually when I have a project that is 2hrs or slightly over when I export to compressor I do it in two parts and burn 2 DVDS or BD’s. I am wondering if I should be able to fit the whole thing on one disc in good quality? Is there a big difference between the mpeg2 setting best quality 90minutes vs best quality 120?
    Laura Weinstein replied 15 years, 2 months ago 3 Members · 5 Replies
  • Michael Gissing
    June 22, 2011 at 9:10 am
    DVDs were designed to fit up to 3 hours of mpeg2 in dual layer. The difference between 90 best and 120 best will not be such a big deal and prefereable to having to load two disks, but if you go dual layer, then 90 best will fit three hours anyway.
    So a better bet is to use dual layer and maintain the same quality as you are doing with two single layer disks
  • Chris Tompkins
    June 22, 2011 at 11:28 am
    You should be able to fit 2 hours on a disc and have it look ok.
    Adjust the data rate in COmpressor a little bit, Dial it in till you make it just 4.2GB in file size when done.
    Chris Tompkins
    Video Atlanta LLC
  • Laura Weinstein
    June 22, 2011 at 4:40 pm
    so if I want the quality to the be the best possible without using dual layer that basically means I need to split it?
  • Chris Tompkins
    June 22, 2011 at 4:50 pm
    It’s always a trade off – high quality – larger files.
    OK Quality – Smaller files, to a degree.
    If you want 2 Hours Highest Quality Compression and No dual layer, then yes, put it on 2 disc.
    I would dial in the data rate until it just fits on 1 disc and then look @ it in your living room and see if it’s good enough for you.
    Chris Tompkins
    Video Atlanta LLC
  • Laura Weinstein
    June 22, 2011 at 5:35 pm
    ok thanks. if the project was for myself I would watch it on television and check the different compressions etc…… but since its for work I have no choice but to make it the highest quality so I’ve exported in part 1 and part 2 (23hrs to go)! Confusing stuff though!
