Activity Forums Apple Final Cut Pro Legacy Compressor setting for HD to SD 8 Bit 16:9 Clip Conversion
  • Compressor setting for HD to SD 8 Bit 16:9 Clip Conversion
    Posted by Tom Daigon on April 25, 2009 at 4:47 pm
    I am attempting to use Compressor for a HD to SD 8 Bit 16:9 clip conversion. Various presets have been used but none give me a 16:9
    letterbox treatment. Can anyone give me the details so I can configure the Inspector to give me this result? I have Googled extensively but havnt found any info that pertains to this particualr process. Thnaks!
    Michael Sacci replied 17 years, 5 months ago 2 Members · 3 Replies
  • Michael Sacci
    April 25, 2009 at 6:47 pm
    That is because it should be though of as 4:3 Letterbox, the pixels are .9 in your final video but you scale and distort the image to give you a 16:9 look on a 4:3 screen.
    Compressor Settings
    Encoder>Video Format>Aspect Ratio: 4:3
    Geometry>Padding: 16X9 1.78:1
    everything else is as you need it.
  • Tom Daigon
    April 25, 2009 at 11:12 pm
    Michael, thanks for your response. I understand the Geometry padding setting, but I am currently looking at the Encoder screen of the Inspector and I see File Format …Extension…Video Settings (I checked here but there is only options for compression type and frame rate and key frames and data rate) …Audio settings and Streaming options where I can change paramenters. But I dont see a Video Format>Aspect Ratio option that can be changed…Can you tell me where it is located?
  • Michael Sacci
    April 26, 2009 at 5:16 am
    Sorry, if you are going to a format that is HD and SD (Uncompressed or ProRes) you should set the Dimension (encoded pixels) to Pixel Aspect to NTSC CCIR601/DV then the padding, it will look wrong in the preview but the export should be fine.
