Activity Forums Apple Final Cut Pro Legacy compressor setting for H_264
  • compressor setting for H_264
    Posted by Michael Noble on February 15, 2007 at 8:41 pm
    Everything is great until I make the DVD. I still get a slight flicker on movement.
    My settings on compressors inspector are as follows.
    File Format Mpeg-2
    Ext M2v
    Video Format NTSC
    Rate 29.97
    Aspect 16:9 (material is shot HDV 1080I60 16X9)
    Field Dominance Bottom First
    Do you see anything wrong?
    Thank you so much for your help.
    Paul Coull replied 19 years, 7 months ago 3 Members · 5 Replies
  • Walter Biscardi
    February 15, 2007 at 9:19 pm
    [RattleItFilms] “Aspect 16:9 (material is shot HDV 1080I60 16X9)
    Do you see anything wrong?”
    1080i/60 is Upper Field First.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Paul Coull
    February 15, 2007 at 9:31 pm
    I have had this problem before for both mastering to beta and dvd, what I didn’t know was that final cut was adding shift fields to the individual clips filters. Once I un-selected it everyhting was fine.
    Also I thought dvd studio ntsc had to be 30fps.
    grafxflow
  • Michael Noble
    February 16, 2007 at 4:07 am
    Where do I un-select this in FCP?
  • Michael Noble
    February 16, 2007 at 4:10 am
    Walter,
    Do you think by adding a Nattress film effect (GFilm Extra V2.5.1)
    would cause me problems as well. I changed the field dominance and it made some
    difference but the effect could still be causing this blurr/flicker on movement
    on the DVD burn?
  • Paul Coull
    February 16, 2007 at 7:33 am
    When in final cut go to the browser window and select your individual clips, not sequence. Then when the viewer window opens select filters, it should be there.
    grafxflow
