Activity Forums Compression Techniques Compressor setting ?
  • Compressor setting ?
    Posted by Jeffrey Stoner on September 20, 2010 at 3:38 pm
    The clip (below) was shot and edited in SD. Brought into Compressor and converted to HD mp4 and then uploaded to vimeo (I do find the resulting video quality on vimeo to be better with SD projects)
    https://vimeo.com/15126248
    You’ll notice that in clips with horizontal movement, there are jaggy artifacts on the edges. You’ll notice it on the groom’s legs when he enters the church around the :30 second mark, and several other shots.
    Is there a setting in Compressor that I should change to fix this?
    Rich Rubasch replied 15 years, 12 months ago 3 Members · 2 Replies
  • Mike Tomei
    September 20, 2010 at 5:12 pm
    What format was this shot in? Most importantly, what frame rate and interlaced/progressive settings?
    Mike
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
    Adobe Production Premium CS5
  • Rich Rubasch
    September 24, 2010 at 2:09 am
    Enable Frame Controls and use the presets…try that.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
