Activity › Forums › Apple Final Cut Pro Legacy › Compressor Reverse Telecine removing wrong frames
  • Compressor Reverse Telecine removing wrong frames
    Posted by Jared Varava on February 19, 2010 at 8:38 pm
    I have a project that started on film (24fps) and was telecined to DigiBeta. That digibeta has been digitized and I’m now attempting to use the reverse telecine process in Compressor to remove the interlaced frames. Instead, Compressor seems to LEAVE the interlaced frames and remove the frames I want to keep as it brings it all back to 24fps.
    I was JUST successful doing this on a different project with the same process, but now can’t get it to work.
    Any ideas???
    Thank you!
    Matt Campbell replied 16 years, 7 months ago 2 Members · 1 Reply
  • Matt Campbell
    February 23, 2010 at 4:45 pm
    Not to familiar with cinema tools but that might help. If not in Compressor, are you using the frame controls? These create a much nicer looking clip.
    OS 10.5.5, Mac Pro 2 x 3 ghz quad-core intel xenon, 9 gb ram, with BM Intensity Pro card
