Activity Forums Apple Final Cut Pro Legacy Compressor; retracing previous compressor settings – historical logs?
  • Compressor; retracing previous compressor settings – historical logs?
    Posted by Ryan Reinike on February 24, 2010 at 3:56 pm
    Searched the forum for duplicate post, but couldn’t find one, so apologies if this has been asked before.
    The short: Is there a way to determine the video export settings one used in the recent past (5 days) from Compressor, assuming one didn’t save these settings. (Assume the ‘one’ in this is me).
    The long:
    I’m doing some HD -> SD alchemy and am going thru different permutations of Comp settings.
    I came upon a setting I had tinkered with by pulling from various posts and sugs to others problems.
    I like the resulting DVD, but it took about 80 hours to render 45mins on my MBP 2,2 2.33 using both cores in cluster w/4GB ram (3 addressable in this MBP flavor); I used a 30 gallon stew pot as a heat sink by turning it upside down and resting the naked bottom of my MPB on it, which drew heat about 1/3 of the way down the pot.
    The DVD looks so crisp (text too) that I want to grab some dip and munch on it. Below is a frame exported from the FCP timeline with just ‘Deinterlace – Lower’ filter applied this was before it went to Compressor. The next frame is from the DVD, snapshot out of VLC.
    So if I can find a log of what I did I could start toning the settings down to save on time and see where the line is that starts reducing the clarity.
    Much thanks,
    Ryan
    From FCP (3mb):
    FCP_stillDVD_still
    Ryan Reinike replied 16 years, 6 months ago 4 Members · 5 Replies
  • Russell Lasson
    February 24, 2010 at 4:41 pm
    I don’t know of any log, but if you drag the file that you created into the setting folder, it should create a new preset based on the settings you used, though I don’t know if it will show any advanced settings.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • John Pale
    February 24, 2010 at 5:25 pm
    Yes. There is a history pane. You can drag any job back to the batch window and examine it. I have not done it in awhile, but I think you can even have a new media file inherit the settings using drag and drop
  • Ryan Reinike
    February 24, 2010 at 6:06 pm
    Thanks John, just the thing!
    Russ, thanks for the reply, but I didn’t mention that I had purged that setting as it took three days and I wanted it gone from existence at the time it finally finished.
    Ryan
  • John Fishback
    February 26, 2010 at 4:59 pm
    Here’s a tutorial.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Ryan Reinike
    March 1, 2010 at 10:23 pm
    Cor, thanks John – excellent cherry on top!
