Activity › Forums › Apple Final Cut Pro Legacy › Compressor Resizing issue
  • Compressor Resizing issue
    Posted by Adam Carrier on June 30, 2011 at 7:47 pm
    I’m trying to deinterlace and resize my 720x486i ProRes422 video into 720x480p ProRes422. However, the resulting encode looks like the attached image. The original footage is there, but there’s a white rectangular block on the right side of the image.
    For the resize, Compressor is cropping 4 pixels from the top and 2 from the bottom. I understand this is the standard way to do this and keep the field dominance the same.
    I have no idea why this is happening. Has anyone seen this before?
    Thanks for any help you can provide.
    Adam Carrier
    Digital Media Technician
    acarrier{at}marinersmuseum{dot}org
    The Mariners’ Museum
    http://www.MarinersMuseum.org
    Adam Carrier replied 15 years, 2 months ago 2 Members · 2 Replies
  • Chris Borjis
    June 30, 2011 at 9:17 pm
    whoa! that is odd.
    Is there any particular reason you’re nipping off the 6 lines and making it progressive?
  • Adam Carrier
    July 1, 2011 at 1:36 pm
    Hi Chris:
    I’m trimming the 6 pixels (4 from the top and 2 from the bottom) to convert broadcast video for edit and then final output for an MPEG2 media player appliance. The MPEG2 video I get from Compressor will have green artifacts if I use 720×486 as my input dimensions.
    The white rectangle thing is just odd. I’ve never encountered it before.
    I’m going to see if Adobe Premiere can output the 480p I need without the rectangle issue –as I’m thinking of switching to Premiere anyway after this whole FCPX storm.
    Adam Carrier
