Activity › Forums › Compression Techniques › Compressor reporting estimated file sizes that are way off–why?
  • Compressor reporting estimated file sizes that are way off–why?
    Posted by Benjamin Reichman on August 24, 2011 at 3:07 pm
    I just compressed two XDCAM EX sequences (about 35-40 min each) into H.264, using the “Quicktime H.264” setting in Compressor. I set a specific bitrate (1500) and Compressor estimated the size of one video at 427.07MB. The finished file is actually 574.5MB. The other video had a similar discrepancy.
    Why would the Compressor estimated size be so different from the real size, when I chose a fixed bitrate?
    The reason this matters is that I’m uploading to a client’s own free Vimeo account, and I have to get the videos under 500MB to post. So I’ll have to recompress these with even lower settings–but I want to make sure I’m only compressing as much as I have to.
    I’m using FCP 7.0 and OS X 10.6.8.
    Benjamin Reichman replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
