Activity Forums Apple Final Cut Pro Legacy compressor reinstall blues
  • compressor reinstall blues
    Posted by Paul Nevison on August 11, 2008 at 7:58 am
    Hey All,
    I had an issue with Compressor where I had a job that got stuck in the render que and I just couldn’t flush it out. I ended up trashing compressor and had planned to reinstall it from scratch.
    However, now when I put my FCP2 install disks in, the option to install any of the FCP suite programmes is greyed out.
    any ideas?
    Alexander Kallas replied 18 years, 1 month ago 3 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    August 11, 2008 at 9:25 am
    Unistalling Compressor is not just to through the Application to the trash.
    You must fallow some precise steps:
    https://support.apple.com/kb/TS1888
    Try that.
    Rafael
    http://www.nagavideo.com
  • Paul Nevison
    August 11, 2008 at 9:50 am
    thanks Rafael
    yes knew there was more to trashing an app than simply trashing the icon in the apps folder…i wasn’t sure of the checklist for all the associated compressor files, but that link is very helpful…..my outstanding question is when will apple build an easy uninstall option?? Is there a technical barrier to why it can’t be done? I’m sure someone must have written an apple script to perform just such a task……i”m off to google the answer!
    Macpro Duel core 3Ghz
    4.0G RAM
    OS 10.4.11
    QT 7.3.1
    FCP 6.0.2
    AE CS3 8.0.1.8
    BMD Decklink HD Extreme 6.6
    PAL Land
  • Rafael Amador
    August 11, 2008 at 11:25 am
    Hi Paul,
    What Apple should also improve is the “Optimizing System” that appear after any Apple installation.
    Even if you make the cleanest installation from scratches in a brand new HD, the result is such a mess inside the Mac OX that is impossible to run properly an application like FC.
    Rafael
  • Alexander Kallas
    August 11, 2008 at 12:10 pm
    Hi Guys,
    What about AppZapper https://appzapper.com/
    Cheers
    Alexander
  • Rafael Amador
    August 11, 2008 at 1:29 pm
    Hi Alexander,
    How are you?
    I prefer don’t need to uninstall nothing, but for $12.90 is even tempting to give it a try.
    rafael
  • Alexander Kallas
    August 11, 2008 at 10:47 pm
    [Rafael Amador] “I prefer don’t need to uninstall nothing, but for $12.90 is even tempting to give it a try.
    rafael “
    Hi Rafael,
    I’m good thanks, even better pricewise is AppDelete, it’s free!
    I agree about the mess any install makes on the HD.
    I’ve come to using Diskwarrior between each install, makes the directory cleaner.
    Cheers
    Alexander
  • Rafael Amador
    August 12, 2008 at 4:19 am
    Hi Alexander,
    I really don’t understand how some people can run a Mac without DW or TT.
    For me is the first software to purchase no matter if you are making video, music or even if you use your Mac only to kill aliens.
    The thing I like the most from TT is the e-Disk. You don’t need to boot from a CD or any other external HD to do all the cleaning.
    rafael
  • Alexander Kallas
    August 12, 2008 at 5:52 am
    Hi Rafael.
    What do you think are the relative strengths and weaknesses of DW and TT?
    Comments please
    Cheers
    Alexander
  • Alexander Kallas
    August 17, 2008 at 11:53 pm
    Another free-bee for deleting FCP
    https://www.digitalrebellion.com/fcs_remover.htm
    Cheers
    Alexander
